Posted: β2020-07-03 12:48 PM . Last Modified: β2024-04-08 01:49 AM
Hi Team,
I have a DCO server running 8.03, and I have tried the following via the webclient:
Add equipment from the equipment library (genomes) into a rack
Is this a know limitation ??
(CID:111413998)
Hi Cees,
Seems you are right, I was able to see a similar behavior testing on a mini IPAD as well - it's now been logged as an enhancement case.
Thank you,
Kind regards
(CID:111414366)
Hi Cees,
Thank you,
Kind regards
(CID:111414366)
Posted: β2020-07-03 12:48 PM . Last Modified: β2023-10-22 04:17 AM
