Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 12:48 PM . Last Modified: 2024-04-08 01:49 AM
How do you set DCE to send out reports via email in CSV format instead of text file?
Martin
(CID:111413986)
Dear Martin,
I am sorry to disappoint you. This feature is not currently available in DCE to send scheduled reports in the form of .CSV through email. It can send it in .TXT format currently which can be then opened in .CSV format manually. You may raise this as a feature request on EcoStruxure IT Help Center -feature request section.
There is an easy way to export the reports in .CSV format. DCE allows you to generate the reports directly in the form .CSV either through UI & on Web client. Please refer the tips here.
regards,
Bala
(CID:111414023)
Dear Martin,
regards,
Bala
(CID:111414023)
Thank you for your response, I have submitted a Feature Request for the above.
(CID:111414170)
Posted: 2020-07-03 12:48 PM . Last Modified: 2023-10-22 01:27 AM
