Posted: ‎2020-07-03 05:43 AM . Last Modified: ‎2024-04-08 11:15 PM
Hi Friends!
In DCM I have warning:
"You are using a reference implementation of the managment console which supports managing up to 64 nodes. The current number of nodes managed is 440."
Be so kind to explain this issue.
(CID:108824352)
The message only relates to the web interface of Intel DCM (which is not officially supported with ITO).
The instance does support monitoring the nodes you have discovered.
(CID:108824466)
(CID:108824466)
Posted: ‎2020-07-03 05:43 AM . Last Modified: ‎2023-10-31 11:42 PM
