Posted: 2020-07-03 05:14 PM . Last Modified: 2024-04-08 12:16 AM
I have a structureware in my datacenter and some NetBotz controllers(450,200 and 150). I need to recieve notifications from sensores .I know that I can connect the GSM modem to NetBotz 450 to recieve these messages but I don't want to buy another GSM modem and connect it to the controller.
I wanna know if it is possible to use one GSM modem in the infrastructure and recieve notifications from all sensores that connect to any controllers?
PS: I have several buildings which the connection between them is ethernet and there is no way to connect controllers directly.
(CID:120136167)
Hi Mohrau,
Sorry but no, StruxureWare DCE does not have the capability to connect to a GSM modem and alert. As you noted, the individual NetBotz can do this but DCE can not. DCE can send normal e-mail and you may want to look into an e-mail to GSM gateway if this is a requirement. There is nothing specific that we support nor have I had any experience with them but I've searched the web and seen a number of them out there.
Steve.
(CID:120136276)
Hi Steve
Thanks.I expected APC to consider this issue because it is better to use central GSM modem for one organisation.
(CID:122685133)
Hi Mohrau,
I know DCE version 7.x will likely not have this feature as it has been requested in the past. I'll still put this post in on that request.
Steve
(CID:122685136)
Posted: 2020-07-03 05:15 PM . Last Modified: 2023-10-22 04:14 AM
