Posted: 2020-07-05 05:36 PM . Last Modified: 2024-04-03 03:18 AM
My users cannot change their own password for DCE - as they are not administrators. I can administer passwords from my end however for remote users this doesn't seem very secure that I have to set a password for them that cannot be changed.
Is the ability to change your own password a possibility in either the DCE Application or Web Browser, without needing administrator privileges?
Thanks!
(CID:140709673)
Dear Sean Hilliar,
From your question:
Unfortunately for the latest version of DCE-7.x this is not possible.
I can only recommend you to create an appropriate Feature requests on this issue.
With respect.
(CID:140709721)
Hi Sean,
The password reset procedure can be performed if you have local access to the DCE server.
The steps are outlined in the document from the link below:
https://www.schneider-electric.com/en/faqs/FA158547/
I hope this helps.
Justine
(CID:140709709)
Dear Sean Hilliar,
From your question:
With respect.
(CID:140709721)
Thank you, I have raised the Feature Request and look forward to potentially seeing this in a future update.
(CID:140709729)
Ok, thanks for the good feedback 😀.
(CID:140709739)
Hi Sean,
as was mentioned in the previous replies, users directly added to DCE can not change their passwords. DCE does have an LDAP/AD integration feature where the domain users password is changed at their login on their computer and that change directly effects their DCE login.
Steve.
(CID:140709731)
Posted: 2020-07-05 05:37 PM . Last Modified: 2023-10-22 04:13 AM
