Posted: 2020-07-03 09:56 AM . Last Modified: 2024-04-08 02:43 AM
Unable to find the versions of software between InfrastruXture Central 6.0.1 and StruxureWare Data Center Expert 7.x or the current revision. Anyone done this upgrade?
(CID:110015928)
Rodney,
To upgrade to the most recent version, the upgrade path would be:
6.0.1 > 6.2 > 6.3 > 7.0.0 > 7.2.0 > 7.2.1 > 7.2.2 > 7.2.4 > 7.2.5 > 7.2.6 > 7.2.7 > 7.3.1 > 7.4.2
You can contact your local technical support for them to verify your software support and provide upgrades.
Cory
(CID:110015932)
Hi Rodney,
Yes, we have done the upgrade from 6.01 to 7.4.2(6.0.1 > 6.2 > 6.3 > 7.0.0 > 7.2.0 > 7.2.1 > 7.2.2 > 7.2.4 > 7.2.5 > 7.2.6 > 7.2.7 > 7.3.1 > 7.4.2). I know it is a lengthy process, but it is how it works.
Please do take the current full backup before proceeding for the upgrade. In case if there is any issue while upgrading, you can use the backup file for restoration.
Bala
(CID:110015937)
Posted: 2020-07-03 09:57 AM . Last Modified: 2024-04-08 02:43 AM
Hi Rodney Reddick,
Change, please, a post topic from DCO to DCE. The post interesting also has to be correctly identified.
Thanks.
(CID:110016365)
Posted: 2020-07-03 09:57 AM . Last Modified: 2023-10-22 04:12 AM
