Posted: 2020-07-02 11:55 PM . Last Modified: 2024-04-09 01:04 AM
Hi All,
how can I download the logs from uniflair Pco Web card.
Ali.
(CID:105465939)
Posted: 2020-07-02 11:56 PM . Last Modified: 2024-04-09 01:04 AM
Hi Ali, thank you for posting! @community - any suggestions here? Best, Stine
(CID:105466055)
Hi Ali
I used a different approach, instead of getting the logs directly from pcoweb (I could not figure out how), created several SNMP variables and then using the Data Center Expert as trap reciver i get those values on to the DCE and from there i create my records.
Best reagards
Antonio
(CID:105466082)
Posted: 2020-07-02 11:56 PM . Last Modified: 2023-10-31 11:40 PM
