Posted: 2020-07-02 01:54 PM . Last Modified: 2024-04-09 04:23 AM
The DCO 7.5 Client opening perfectly based on DCO Server IP Address.
But its failed to open using with DCO Host name as assigned.
From Network Team, The Host name already mapped with local DNS servers and Destination Client Access PC for the following ports as requested..
80 | http |
443 | https |
4457 | tcp |
4460 | tcp |
4459 | ssl |
4462 | ssl |
53 | TCP |
DCO Hostname not working with DCO Client.
DCO Host name working with Browser
DCO Server - Hostname webmin settings
Please advice what else to be required to activate for DCO 7.5 Client access based on Host name.
(CID:99156683)
Hi Venkatasubramaniam, thanks for posting! @community - any advices?
(CID:99156734)
Hi Venkat,
It would be interesting to know what the "ping hostname" would return, and the result of nslookup on hostname.
This might be a proxy related issue - it seems there is a direct route to the server when using the IP address, but it is routed through a proxy server when using the hostname. The connection timeout error might be an indication that possibly a proxy server is not permitting the traffic.
(CID:99156747)
Posted: 2020-07-02 01:55 PM . Last Modified: 2024-04-09 04:23 AM
Thanks Jef. After added the DCO IP address and Hostname entry in Windows Host file, able to login the Client using Host name.
(CID:99156837)
My pleasure Venkat, excellent!, happy to hear that problem is resolved & many thanks for getting back and sharing.
(CID:99156838)
Posted: 2020-07-02 01:55 PM . Last Modified: 2023-10-31 11:40 PM
