Customize DCE report
  • EcoStruxure IT forum
  • Customize DCE report
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 01:55 PM . Last Modified: ‎2024-04-09 04:22 AM
595
Hi team, where can I find details on how to customize DCE reports? I would like to add a header with a logo on it and format data a certain way. Is this something we can do by customizing an existing report in DCE?
(CID:99156698)
595
Ajay,
Reports within DCE are not customizable to the extent that you would like.  You can run a report and then export the data for manipulation within Excel.  Once the data is exported to excel, it can be manipulated and then structured into the desired format.  DCE will not be able to send this report.  They would have to manually send it via email (or another manner) to the recipients.
Data or graphs can easily be exported from DCE by using the following options from within the generated report:
Best Regards,
Cory
(CID:99156700)
596
Ajay,
Best Regards,
Cory
(CID:99156700)
Thanks for the detailed clarification, Cory. I will look into the option of manipulating DCE report output.
(CID:99156701)
Posted: ‎2020-07-02 01:55 PM . Last Modified: ‎2023-10-31 10:22 PM
