Unable to access EcoStruxure IT API via cURL command
  • Unable to access EcoStruxure IT API via cURL command
126
65
scoop263
Crewman scoop263
Crewman
Posted: ‎2024-06-10 12:38 PM
697
I am attempting to try to automate tasks in EcoStruxure IT DCE 8.1.0 and i am having a difficult time obtaining the access token. When reading the REST API information on my server's webpage, it indicates that I need to perform the following command:
POST /oauth/token username username password password grant_type password
However the issue is that when I use the cURL command, it will fail.
In documentation, it appears that to access the API i need to user https://hostname/isxg/rest however this will fail as i cant POST to it, as it tries to redirect to this webpage instead https://hostname/isxg/dce-rest-api.html.
I have also attempted to access the api using /isxg/api and /isxg/oauth/token
This is also my first introduction to using APIs.
If i could get some guidance on where i should be making this POST request to, that will be great.
I am able to get access using the API if i use the webUI to create my token and provide it, but again, Id like to try and achieve only using linux commands.
Admiral
Posted: ‎2024-06-11 07:36 AM
Hi @scoop263,
Here is an example cURL command for getting a token:
curl --location --request POST 'https://10.10.10.10/isxg/oauth/token?grant_type=password&password=apc&username=apc' \
To refresh the token use the REFRESH token that you received in your original token request above.  This will provide you with a new token and new refresh token.
curl --location --request POST 'https://10.10.10.10/isxg/oauth/token?grant_type=refresh_token&refresh_token=f13f9d94-839e-44e9-b681-55f18aa2119e&=' \
Kind Regards,
Cory
Admiral
Hi @scoop263,
Kind Regards,
Cory
