Posted: 2020-07-02 08:11 AM . Last Modified: 2024-04-10 01:34 AM
Hi, I feel like idiot but I was not able to find solution of my problem.
I did our server room but I have problem I import doors but I am not able too turn them on the wall.
For better explanation I have picture:
Thx 4 help
Zdeněk Novotný
(CID:89064020)
Hi Zdeněk,
Again, there are two kinds of walls here. Referring to your snapshots.
A> The Generic Room Wall, which's the one created during room creation.
On this wall, you can snap your door easily(with inner opening).
B> Manually created wall:
These walls are meant to display compartmentalization(like a staging area or some rooms withing the server room). Here you might not be able to snap your door always(but can indicate, as you have), depending upon the orientation of the wall.
(CID:89064056)
Hi Zdeněk,
Which exact version are you running? (Can be found in the "About StruxureWare Data Center Operation")
In version 7.3.6 and above you are able just to drag the door across the wall and it would snap to wall leaving the clearance area inside the room boundaries. Not knowing your version there might also be an orientation option in the physical properties of the door it self.
(CID:89064024)
Hi Zdeněk,
(CID:89064056)
Thx for help. 😀
Have a nice day.
Zdeněk
(CID:89064063)
Posted: 2020-07-02 08:12 AM . Last Modified: 2024-04-10 01:34 AM
(CID:89064065)
Posted: 2020-07-02 08:12 AM . Last Modified: 2023-10-31 11:39 PM
