Posted: 2020-07-04 09:44 PM . Last Modified: 2024-04-04 03:34 AM
Tittle: MTC-H5-B03 Modem Not Working With Netbotz 450
Hi There,
i have Multitech Modem USB MTC-H5-B03 and i connected this modem to Netbotz 0450 with USB cable but its not showing any thing in Advance View 4.6.2. Can Any One Help me sort this Out?
(CID:133371649)
Hi Nisar,
Good day!
The supported modems that can be used with Netbotz v3 (which includes Netbotz 450) are listed on the article from the link below:
http://www.apc.com/au/en/faqs/index?page=content&id=FA158359
Unfortunately, I do not see Multitech Modem USB MTC-H5-B03 on the list of supported modems. However, feel free to consider the modem models listed in the article to ensure its compatibility.
I hope this answers your question.
Justine Chester
(CID:133371743)
Dear Nisar Ahmed ,
Finally, make sure that this GSM/GPRS modem model is not supported, by viewing the logs of your NetBotz-450. To do this, go through the link http://NetBotz_address/pages/support.html and click on the logread button. In addition, you can use the modem diagnostics page http://NetBotz_address/pages/modem.html .
Try and tell us please the result.
With respect.
(CID:133371787)
Dear Nisar,
Please see my earlier post on the same modem issue which worked after we reset the netbotz appliance to factory defaults, and then re-configured the modem.
You can also follow my tip that I posted to make this work. Please follow the step by step instructions, and see if it helps.
regards,
Bala
(CID:133372805)
(CID:133375845)
Posted: 2020-07-04 09:44 PM . Last Modified: 2024-04-04 03:33 AM
Dear Nisar,
Have you tried in resetting the Netbotz appliance to factory defaults by using the method described in the below K-base document?
http://www.apc.com/us/en/faqs/FA158175/
Did you try Method:2?
If so, you can follow the below K-base document instructions which has got procedure for restoring a NetBotz appliance to default due to unknown configuration issues or other unknown behavior on a NetBotz appliance.
http://www.apc.com/us/en/faqs/FA176133/
If you need quick help, you can also call in our customer care and find the contact details of customer care here.
I hope this helps.
(CID:133375883)
Posted: 2020-07-04 09:44 PM . Last Modified: 2023-10-22 04:07 AM
