This model has extended power information from genome library
  • This model has extended power information from genome library
129
72
Posted: ‎2020-07-05 11:43 PM . Last Modified: ‎2024-04-03 12:02 AM
1831
When I try to edit the power properties of the rack PDU APC AP8853 (either in the Genomes or after having added it in my data center), the following information message appears and the system won't let me edit the power properties (e.g. power input):
"This model has extended power information from genome library"
Any ideas to overcome this issue?
(CID:152077782)
  • Data Center Operation
  • Genome
  • bug
Hi Nikolaos,
That is a new feature in DCO for some rack PDUs with banks and outlets definitions (they are well defined so you cannot modify). If you need to modify/customize a device, then select another item (from the Genome Library).
From 8.3 release in genome library there are rack PDUs with additional banks and outlets definition. more details here: https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Working+with+Rack+PDUs
Kind regards
(CID:152077796)
Hi Nikolaos,
Kind regards
(CID:152077796)
Posted: ‎2020-07-05 11:43 PM . Last Modified: ‎2023-10-22 04:07 AM
