Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
There is one hour difference between DCE and Report Graphic Screen
  • EcoStruxure IT forum
  • There is one hour difference between DCE and Report Graphic Screen
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 01:14 AM . Last Modified: ‎2024-04-09 12:40 AM
670
Our DCIM "Data Center Expert - V7.2.6"  time and Report Screen Time is one hour difference .
(CID:105468943)
Hi Seref,
Have you verified the date and time set on the server? It is possible there is  time difference there. Have you checked the devices? What is their time configuration. When running the report, what options did you choose, relative or a specific range? Have you tried the other? DCE will report data based on not only it's clock but the clock on the devices as well. Run a report instead of a graph to see these values.
Steve
(CID:105468970)
Hi Seref,
Steve
(CID:105468970)
(CID:105469629)
Posted: ‎2020-07-03 01:14 AM . Last Modified: ‎2023-10-31 11:38 PM
