Posted: 2020-07-02 12:21 PM . Last Modified: 2024-04-09 11:53 PM
Hello All, I am new to using the TSXETG100 and have created a little test environment to convert from a Netbotz 200 RS485 Modbus serial output to the TSXETG100 and then using a tool called MODSCAN32 (but there are lots around) to view the Modbus registers.
The NB200 Modbus registers state that they range from 000h (0dec) to 0344h (834dec) but while I don't get any read errors (Modscan is saying it polling OK) I don't get any meaningful information from the TSXETG100.
I believe I am polling the NB200 correctly but I cannot interrogate any of the right registers (they all return 2 except for 40001 which returns 2.
Can someone point me in the right direction for a MODBUS/IP tool to read the registers in the appropriate range?
Craig
(CID:96044736)
Hi Craig!
In fact, you need to increase register number by 1 in order to obtain right information. So if you want to receive model name, for example, you need to start polling from register 40278 instead of 40277.
I think that your issue is related to results interpretation by Modscan software. I recomend you to try another one. I use CAS Modbus Scanner.
For find it out you can go to Diagnostic page of TSXETG and see what values are received by gateway.
For example:
(CID:96044772)
Posted: 2020-07-02 12:22 PM . Last Modified: 2023-10-31 11:39 PM
