Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Symmetra MW in DCE firmware versions
  • EcoStruxure IT forum
  • Symmetra MW in DCE firmware versions
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:28 PM . Last Modified: ‎2024-04-05 12:33 AM
961
customer has DCE and wants to see more than only the display firmware version like the main controller and power module firmware versions.
The only thing you see now is the Display firmware version.
See picture below
Is there a possobility to see the firmware of the main controller and the firmware of the power modules ?????.
and if not will this come in a newer version of the DCE  visible ??.
Hope to hear from you soon.
(CID:129408689)
961
Hi Frans,
From what I can see, these values are not available in the modbus register map for the Symmetra MW. If the device does not output the value, StruxureWare DCE can not provide that value in it's interface. To get DCE to show these values, you'd need to have those values in the device then have the DDF team include the values in the DDF. Your request would need to be made of the UPS engineering team, not DCE.
Steve
(CID:129408718)
Replies 4
962
Hi Frans,
Steve
(CID:129408718)
Thanks Steve for your quick answer.
(CID:129412008)
Sent off-line email
(CID:129408758)
Posted: ‎2020-07-04 03:29 PM . Last Modified: ‎2023-10-22 04:04 AM
