Posted: 2020-07-04 03:28 PM . Last Modified: 2024-04-05 12:33 AM
customer has DCE and wants to see more than only the display firmware version like the main controller and power module firmware versions.
The only thing you see now is the Display firmware version.
See picture below
Is there a possobility to see the firmware of the main controller and the firmware of the power modules ?????.
and if not will this come in a newer version of the DCE visible ??.
Hope to hear from you soon.
(CID:129408689)
Hi Frans,
From what I can see, these values are not available in the modbus register map for the Symmetra MW. If the device does not output the value, StruxureWare DCE can not provide that value in it's interface. To get DCE to show these values, you'd need to have those values in the device then have the DDF team include the values in the DDF. Your request would need to be made of the UPS engineering team, not DCE.
(CID:129408718)
Hi Frans,
(CID:129408718)
Thanks Steve for your quick answer.
(CID:129412008)
Sent off-line email
(CID:129408758)
Posted: 2020-07-04 03:29 PM . Last Modified: 2023-10-22 04:04 AM
