Posted: 2020-07-02 01:12 PM . Last Modified: 2024-04-09 04:38 AM
Hi Currently I have Struxureware 7.2.5 that is working with active directory 2003, I want to upgrade my Active Directory 2012 R2 and keep the functionality level to 2012 R2.
Does struxureware is compatible with the 2012 R2 AD authentication ?
(CID:97485549)
Hi Adil,
Just an update, I heard from engineering and I'm told:
DCE 7.2.4 - 7.2.7 was tested against an Active Directory server running Windows 2012 r2
They used what was available, not that they tested with a bunch of different versions of AD.
Steve
(CID:97485562)
Hi Adil,
To my knowledge, there has been no specific testing with specific versions of Active Directory. If you change your AD server, you will potentially need to create a new remote authorization entry within DCE but I can say that I have heard of no issues with respect to active directory versions.
Steve
(CID:97485551)
Thanks Steve.
(CID:97485555)
Welcome
(CID:97485559)
Hi Adil,
Steve
(CID:97485562)
Great, thanks for the usefull information
(CID:97485563)
Posted: 2020-07-02 01:12 PM . Last Modified: 2023-10-31 11:37 PM
