Struxureware Portal TLS issue
  • EcoStruxure IT forum
  • Struxureware Portal TLS issue
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:45 PM . Last Modified: ‎2024-04-03 02:53 AM
1092
Hi Team,
I have the following issue on my Portal:  TLS Error shows up but the server and services are running as expected.
TLS settings are as follows:
Any other possible causes for this issue?
Regards
(CID:141271980)
  • Data Center Operation
  • Portal
  • bug
Hello Thabo. Have you or someone used the instructions on this link https://sxwhelpcenter.ecostruxureit.com/display/Portal/Enable+SSL+in+StruxureWare+Portal to enable a secured connection to the portal?
By default, portal is not installed in a secured fashion. The default enabled connection is http://:8080/ ... the above procedure will help you enable a https connection on port 8443.
One item of note, to set the portal server to only accept tlsv1.2 connections you will need to follow the above procedure but change the part where to set the contents of the server.xml file to something like this:
maxThreads="150" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLSv1.2"
minSpareThreads="25" maxSpareThreads="75" enableLookups="true" disableUploadTimeout="true"
acceptCount="100" debug="0" keystoreFile="" keystorePass=""/>
The above text  replaces the text in one of the steps from the procedure.. the procedure enables all versions of TLS, most customers would want to restrict that to tlsv1.2.
Regards
Greg Sterling
(CID:143264363)
Posted: ‎2020-07-05 06:45 PM . Last Modified: ‎2023-10-22 04:03 AM
