Posted: 2020-07-05 06:45 PM . Last Modified: 2024-04-03 02:53 AM
Hi Team,
I have the following issue on my Portal: TLS Error shows up but the server and services are running as expected.
TLS settings are as follows:
Any other possible causes for this issue?
(CID:141271980)
Hello Thabo. Have you or someone used the instructions on this link https://sxwhelpcenter.ecostruxureit.com/display/Portal/Enable+SSL+in+StruxureWare+Portal to enable a secured connection to the portal?
By default, portal is not installed in a secured fashion. The default enabled connection is http://
One item of note, to set the portal server to only accept tlsv1.2 connections you will need to follow the above procedure but change the part where to set the contents of the server.xml file to something like this:
maxThreads="150" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLSv1.2"
minSpareThreads="25" maxSpareThreads="75" enableLookups="true" disableUploadTimeout="true"
acceptCount="100" debug="0" keystoreFile="
The above text replaces the text in one of the steps from the procedure.. the procedure enables all versions of TLS, most customers would want to restrict that to tlsv1.2.
Greg Sterling
(CID:143264363)
Posted: 2020-07-05 06:45 PM . Last Modified: 2023-10-22 04:03 AM
