Posted: 2020-07-05 08:06 PM . Last Modified: 2024-04-03 01:20 AM
I'm trying to install ito 7.5.2, but I'm getting the following error, some idea
(CID:145425569)
When you attempted to install ITO did you specify an alternate installation directory/folder? There was a bug in this ITO release which would yield that error if a non-standard installation path was used.
If yes, the current ITO release, 7.5.6 has a fix for that issue. That download is on the same download page as current DCO releases.
Regards
Greg Sterling
(CID:145850488)
Posted: 2020-07-05 08:06 PM . Last Modified: 2023-10-22 04:02 AM
