Posted: 2020-07-03 03:56 AM . Last Modified: 2024-04-08 11:49 PM
Please confirm me can I install StruxureWare portal on VM , or must be in physical server. if YES then what is the requirements for VM.
Ali
(CID:106208120)
Yes StructureWare portal can be installed on a VM. To determine what your requirements are for the VM see System Requirements
(CID:106208122)
This exactly. When I deployed Portal, I did so following the system requirements and had no issues.
(CID:106208145)
Posted: 2020-07-03 03:56 AM . Last Modified: 2023-10-31 11:37 PM
