Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Error importing cert, code: -32
  • EcoStruxure IT forum
  • Error importing cert, code: -32
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:56 AM . Last Modified: ‎2024-04-08 11:49 PM
926
Sehr geehrte Kollegen,
Ich benötige Support beim Generieren der Zertifikate für die APC Hardware.
Leider Ende ich am Schluss vom APC Security Wizrad 1.04 bei folgendem Fehler:
Ich habe mich strickt nach dieser sehr guten Anleitung gehalten:
https://mikeshellenberger.wordpress.com/2010/05/19/issuing-ssl-certificates-to-apc-devices-from-micr...
Was ist der genaue fehler. Was verträgt das  APC Security Wizrad 1.04 nicht. Wir haben das PKI Web Template verwendet, jedoch mit zwei weiteren Werten ergänzt.
Wir verwenden folgenden Microsoft Zertifikatsserver:
Version: 2.6.0
Assigned roles: RA Server Agents
Powerd by: www.keyon.ch
Danke fürs Feedback
(CID:106208155)
  • bug
Replies 5
Posted: ‎2020-07-03 03:57 AM . Last Modified: ‎2024-04-08 11:49 PM
Hi Momcilo Stajic, thanks for posting! Let's see who can be of assistance here. @community - any ideas? Best, Stine
(CID:106209385)
926
Hello Momcilo Stajic,
This issue is discussed in our KBase FA285378. Can you review this and try the recommendation in the Resolution section. Let me know how you get on with this.
Regards
John T
(CID:106209395)
Hello John Thompson, I know your KBase FA285378 and there is in the KBase FA285378 no Resolution for us. Regards Momcilo S
(CID:106209400)
Hi Momcillo, Can you provide details of the Public Key Infrastructure (PKI) and Certificate Authority (CA) you are using. Can you also provide all of the files that were used in the certificate generation process with the Security Wizard. Thanks & Regards John T
(CID:106209567)
Posted: ‎2020-07-03 03:57 AM . Last Modified: ‎2023-10-31 10:57 PM
