Posted: 2020-07-03 03:57 AM . Last Modified: 2024-04-08 11:49 PM
If there is enough Memory/RAM available, then you might want to assign more to Liferay memory allocation pool, that may increase the server performance.
Here is how to do:
go to C: \ Program Files\ StruxureWare Portal \ tomcat-* \ bin
and edit the following files:
"setenv.bat" and "setenv.sh"
and then increase the following numbers:
“-Xmx1024m -XX:MaxPermSize=256m”
example:
“-Xmx4096m -XX:MaxPermSize=1024m”
(CID:106208170)
Posted: 2020-07-03 03:57 AM . Last Modified: 2023-10-31 11:05 PM
