Posted: 2020-07-03 09:03 AM . Last Modified: 2024-04-08 03:40 AM
I running APC StruxureWare Portal version 1.3.4. I can see that daily log files has 4 GB size.
Under installation folder /opt/StruxurewarePortal/liferay-portal-6.1.1-ce-ga2/ I find liferay.2016-11-xy.log files and will run out of disk space.
What can be the reason of this huge logs?
(CID:110008035)
Hi Mate,
I guess "something"(or some integration, such as an authentication server) is not responding and being repeatedly logged in the log file(s). I can take a look at the log file(s) if you would share them with me, thanks.
Kind regards
(CID:110008177)
Posted: 2020-07-03 09:03 AM . Last Modified: 2023-10-22 04:01 AM
