StruxureWare DC Operation configuration on port 10000 not work
  • EcoStruxure IT forum
  • StruxureWare DC Operation configuration on port 10000 not work
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:45 AM . Last Modified: ‎2024-04-09 12:49 AM
760
Hello
I try to install v7.3.6 ISO on debian x64 vm and minimum configuration , installation down and web console come up.
but configure section on port 10000 (webmin) not work and show TLS error.
with win 10 and IE and chrome TLS tick is enabled and telnet to port 10000 is show server ready for data.
client not work and service show following status.
I don't install "StruxureWareDataCenterOperation-Webmin-Module-1.5.tgz" but this module is activated in ISO but not running as show as "sudo service --status-all" command.
who can help me for connect to this application (configuration and client app) step by step?
I want to add insight license after solve this problem.
Thanks Armen
apc@esx:~$ sudo service webmin start
apc@esx:~$ sudo service --status-all
[ + ] acpid
[ + ] apache2
[ - ] bootlogd
[ - ] bootlogs
[ ? ] bootmisc.sh
[ ? ] check_setup.sh
[ ? ] checkfs.sh
[ - ] checkroot.sh
[ ? ] console-setup
[ ? ] cron
[ - ] fancontrol
[ ? ] hdparm
[ - ] hostname.sh
[ ? ] hwclock.sh
[ ? ] hwclockfirst.sh
[ ? ] ifupdown
[ ? ] ifupdown-clean
[ - ] iptables-persistent
[ + ] ipvsadm
[ ? ] kbd
[ ? ] keepalived
[ ? ] keyboard-setup
[ ? ] keymap.sh
[ ? ] killprocs
[ - ] live-boot
[ ? ] live-config
[ - ] lm-sensors
[ ? ] module-init-tools
[ ? ] mountall-bootclean.sh
[ ? ] mountall.sh
[ ? ] mountdevsubfs.sh
[ ? ] mountkernfs.sh
[ ? ] mountnfs-bootclean.sh
[ ? ] mountnfs.sh
[ ? ] mountoverflowtmp
[ ? ] mtab.sh
[ ? ] networking
[ + ] nfs-common
[ + ] ntp
[ + ] operations
[ ? ] operations-monitor
[ + ] portmap
[ + ] postgresql
[ ? ] procps
[ ? ] rc.local
[ - ] rmnologin
[ - ] rsync
[ + ] rsyslog
[ ? ] screen-cleanup
[ ? ] sendsigs
[ - ] smartmontools
[ - ] snmpd
[ + ] ssh
[ - ] stop-bootlogd
[ - ] stop-bootlogd-single
[ ? ] sudo
[ - ] sysstat
[ ? ] udev
[ ? ] udev-mtab
[ ? ] umountfs
[ ? ] umountnfs.sh
[ ? ] umountroot
[ - ] urandom
[ ? ] webmin
apc@esx:~$
(CID:105467847)
  • Data Center Operation
Replies 4
760
Armen. Are you getting a security error when you attempt to connect to webmin. Some newer browser versions will not accept the SSL certificate versions from webmin. You could try the work-around in the following community post (http://dcimsupport.apc.com/questions/97485228/answers/97485338) to see if you can access webmin. The community post describes how to turn off SSL connections to webmin. It also contains a browser work-around which may allow the connection to complete. Regards Greg Sterling
(CID:105468851)
Posted: ‎2020-07-03 12:46 AM . Last Modified: ‎2024-04-09 12:49 AM
Hi Armen, Adding to Greg's comment - I would like to share with you that DCO 7.3.6 is unsupported (many versions old), it is strongly recommended to upgrade the product to the latest version (currently DCO 7.5). Kind regards
(CID:105468853)
Hi soleyman, did you get your client to work? Best, Stine
(CID:105468855)
Posted: ‎2020-07-03 12:46 AM . Last Modified: ‎2023-10-31 11:36 PM
