StruxureOn GW: backup failed on \\localhost\C$ administrative shares?
  • EcoStruxure IT forum
  • StruxureOn GW: backup failed on \\localhost\C$ administrative shares?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 02:21 PM . Last Modified: ‎2024-04-08 01:20 AM
520
Hi all!
Sometimes it is necessary to install and use the server software similar to StruxureOn Gateway, on Windows OS (7/8/10 or 2008/2012/2016) without registration in AD. It is normal both for test environments, and for productive.
But in that case it is possible to face above the specified problem: and it thus that the backup configuration in StruxureOn GW is absolutely true and checked (including access rights and passwords). At the same time in logfile C:\Program Files\StruxureOn Gateway\log\console.log we have mass here of such errors:
03/22/2017:21:38:17.341:ERROR:http-nio-443-exec-3 SmbFileSystem:190 - Change directory Exception: Access is denied.
SOLUTION:
If you are not in a AD: UAC will prevent remote access to administrative shares. Therefore it is necessary set registry option, which allows remote UAC:
Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
Value: LocalAccountTokenFilterPolicy
Data: 1 (to disable, 0 enables filtering)
Type: REG_DWORD (32-bit)
or
REG ADD HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System /v LocalAccountTokenFilterPolicy /t REG_DWORD /d 1
That's it, reboot OS or the StruxureOn Gateway services isn't required, changes are applied immediately.
With best regards.
(CID:114822156)
  • Asset Advisor
Posted: ‎2020-07-03 02:21 PM . Last Modified: ‎2023-10-22 03:59 AM
This is a heading
