Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 02:22 PM . Last Modified: 2024-04-08 01:20 AM
I tried to install ITO 7.5.2 to a Windows 64-bit server but I get the warning below in the middle of setup.. After setup completes, when I look at Windows Services control panel, "SchneiderElectric Energycenter" is not in the services list.
Any suggestions?
(CID:114822176)
Hi Erhan Yasar,
Read my answer to the same problem: Struxureware portal 1.3.5 installation issue in Windows-7. ITO for the work uses Postgresql with at installation there can be problems. Check and be convinced that one more copy of Postgresql service isn't running in system.
With best regards.
(CID:114822201)
Posted: 2020-07-03 02:22 PM . Last Modified: 2023-10-22 02:41 AM
