StruxureOn GW: Unknown alarm power_ups_mxsu_3s [A-0181] is active
  • EcoStruxure IT forum
  • StruxureOn GW: Unknown alarm power_ups_mxsu_3s [A-0181] is active
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:15 PM . Last Modified: ‎2024-04-08 02:32 AM
968
Hi all!
I have found the following bug in StruxureOn GW 1.0.2.9.
Warning "UPS: Warranty expiring soon.":
...is displayed as the unknown critical alert:
In StruxureOn GW is used signed DDF catalog Version 1.1.2.11-SNAPSHOT from December 19, 2016.
Very thanks for the support.
(CID:110791376)
  • Asset Advisor
  • DDF
  • bug
Thanks for sending this in. This is definitely a bug. It's ultimately a compatibility issue between this Gateway version and some of the most recent UPS firmware versions. Fortunately, we encountered the same issue here recently in testing and already have a fix. The fix will be included in the next Gateway update (1.0.3) and should be available within the next 2-3 weeks.
Thanks again!
(CID:110792596)
Thanks again!
(CID:110792596)
Posted: ‎2020-07-03 12:15 PM . Last Modified: ‎2023-10-22 03:59 AM
