Posted: 2020-07-03 12:14 PM . Last Modified: 2024-04-08 02:33 AM
A DCO 8 system has several network devices (showing an "N" in a yellow box next to the Genomes and the modeled device) that have been configured with blade slots. However, I can't find a way to add a blade to these devices. I've checked blade size and orientation and ensured the Family name is an exact match. But I cannot get a blade in these chassis.
Is it correct that "Network Type" devices ("N" n a yellow box) cannot accept blades, even though it is possible to configure them with slots?
I.e. if I need to put blades into the slots of these devices, I have to remodel the Genomes devices as "Blade Chassis" showing "B" in a grey box, delete and recreate the assets?.
(CID:110791340)
Posted: 2020-07-03 12:14 PM . Last Modified: 2024-04-08 02:32 AM
Hi Ed,
Currently in DCO it is supported to add "switch modules" into "switch enclosure", it might fail if there should be mismatch between the module and enclosure. If needed you might want to try customizing/adding "Generic Switch Module" to your network chassis:
Kind regards
(CID:110791617)
Hi Ed Tarento, thanks for posting. Lets see who can be of assistance here. @community any ideas?
Kind regards Ditte
(CID:110791548)
Hi Ed,
Kind regards
(CID:110791617)
Thanks Jef, right you are
(CID:110792231)
You are most welcome, Ed
Kind regards
(CID:110792258)
Posted: 2020-07-03 12:14 PM . Last Modified: 2023-10-22 04:25 AM
