Socomec Diris i30 modbus DDF
  • EcoStruxure IT forum
  • Socomec Diris i30 modbus DDF
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:30 PM . Last Modified: ‎2024-04-03 05:04 AM
2516
I am desperately looking for a socomec i30 modbus DDF.
I am aware of the process and have already logged a request, but would like to find out if anyone has an existing one that works!
(CID:138809318)
Replies 8
Posted: ‎2020-07-05 04:31 PM . Last Modified: ‎2024-04-03 05:04 AM
Can you send me the modbus point list that you attached to your request? I may have a DDF from another manufacture that may be similar. Post your email address and I'll contact you directly.
(CID:138809332)
Hi Bill,
Please attached.
DIRIS-DIGIWARE-I30-HTML-CLIENT_COMMUNICATION-TABLE_CMT_2018-01_MULTI.html
(CID:138809373)
Kevin attachment was removed by site
(CID:138809386)
I received the link through the emailed update and I'll review it.
(CID:138809424)
Thank you Bill.
(CID:138809495)
2516
Kevin the Diris A40 DDF appears to be supported and may be similar in function.
The modbus registers are differant but you can try and alter it yourself as a test. I actually had luck altering the Schneider powerlogic DDF myself.
The ddf/xml that you should try is the "socomec_diris_a40_a41_mfm.xml". There's a zip file under support which gives you 3 versions but this version has the modbus registers in the 50000 series.
(CID:138809604)
Kevin did our conversation help expedite your DDF creation?
(CID:140217489)
Posted: ‎2020-07-05 04:31 PM . Last Modified: ‎2023-10-22 03:57 AM
