IP Address Of Discovered Nodes
  • EcoStruxure IT forum
  • IP Address Of Discovered Nodes
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:30 PM . Last Modified: ‎2024-04-03 05:04 AM
952
It was advertised in DCE 7.6.0 that you can now change the IP of a discovered device w/o losing any data.  Does anyone know how to accomplish this?  I tried changing the IP on the network card interface, but had to rescan for the device and start over.
(CID:138808931)
953
Hi Todd,
After you change the IP on the card itself, you must then go to the SNMP Device Scan settings for that device and change the IP listed there:
You should not have to rediscover the device. This is new to 7.6 and I've tested myself with no issue.
Steve
(CID:138808939)
Replies 4
954
Hi Todd,
Steve
(CID:138808939)
That worked.  Thanks.
(CID:138808952)
Thanks, Steven Marchetti!
Todd Walters, I added a page to the documentation for this. Change the IP address of a discovered device
Thanks for helping us improve!
(CID:138809005)
Posted: ‎2020-07-05 04:30 PM . Last Modified: ‎2023-10-22 02:39 AM
