Posted: 2020-07-02 02:11 PM . Last Modified: 2024-04-09 04:16 AM
I would need to connect 4 Smoke Sensors (NBES0307) to a Netbotz 450. Due to the limit of 2 sensors for the Netbotz 450, would it work to add to it 2 Netbotz Sensors Pods 150 (since, if I understand properly, each Netbotz Sensor Pod 150 can support up to 1 Smoke Sensor)?
Thanks a lot
(CID:99157074)
Hi Antonio,
I believe the limit is 2 smoke sensors per pod. If you have just the appliance, your limit is 2. If you have an appliance with 1 sensor pod (and I suggest you use external power), the limit is 4. 2 external pods and the limit is 6 etc.
Steve
(CID:99157076)
Posted: 2020-07-02 02:11 PM . Last Modified: 2023-10-31 11:35 PM
