Posted: 2020-07-02 02:10 PM . Last Modified: 2024-04-09 04:17 AM
I note the discussion
How do I get to see the param pane in Insight?
I create new repotr and use Inventory, then preview pane
I've tried to adjust Window - Preferences - Web Browser - Use external Web Browser - Default and I also tried Firefox without success.
DCO 7.5.0-42470-8540c, S/N: SV1334D370CV
I was using a 7.5 Insight client from a previous install. I unsinstalled and reinstalled
Insight DataCenterOperationInsight-7.5.0-42470-8540c.windows.x86_64.exe
(CID:99157043)
Hi Ed, Does it work if you preview in another format. Like for instance pdf? Thanks Jesper
(CID:99157098)
Hi Ed Tarento, did you see this? Best, Kristoffer Debois
(CID:99157105)
No other format does anything
With the Layout view selected, when I select menu option Run - View Report - *
Every option simply does nothing.
Guessing it's a Java issue, I checked control panel - when I double click java I get
add remove programs shows:
I'm going to uninstall and resinstall Java and try again
(CID:99157151)
I've un-installed Java, reinstalled and switch to Firefox as my default. Still no luck
Any other ideas?
(CID:99157261)
Posted: 2020-07-02 02:10 PM . Last Modified: 2024-04-09 04:16 AM
I've tried a different system, DCO 7.4.5 and desktop with same results. The "Enter Parameters" dialog remains blank. What am I doing wrong?
(CID:99157263)
Note that we ship our own version of Java (in the "jre" subdirectory of the installed application), the system Java is not used.
(CID:99157262)
It looks like you are using Windows 8 (probably with Internet Explorer 11)? In that case, from the question you are referring to (http://dcimsupport.apc.com/questions/96764122/parameter-pane-is-blank-when-i-preview-an-insight-repo...😞 "Currently the Insight reports are not supported in IE11 - our QA has been informed and they will report an enhancement request on this." and " the report generation in DCO, Planning | DataCenter & Analytics | Reports works fine with IE 11."
(CID:99157265)
Posted: 2020-07-02 02:11 PM . Last Modified: 2024-04-09 04:16 AM
Thanks, I have another laptop with IE 9 (9.0.8.112...) Will that work?
If not, which IE version/s work
(CID:99157300)
Again, if you look at the question you yourself refer to (http://dcimsupport.apc.com/questions/96764122/parameter-pane-is-blank-when-i-preview-an-insight-repo...😞 "If I preview the same rptdesign on a system with IE9 the parameter pane content is visible."
(CID:99157305)
Posted: 2020-07-02 02:11 PM . Last Modified: 2023-10-31 10:19 PM
