Posted: 2020-07-02 03:24 PM . Last Modified: 2024-04-09 03:11 AM
I have a set of devices discovered in DCE (up-to-date, v7.2.7) and everything is working fine except for my 4 InRow RC gen2 (ACRC301s):
The firmware of the InRow is also up-to-date (AOS 6.1 and acrcGen2 6.1) and the SNMP value are default (v1 is enabled).
Is this a problem of definition file?
How should I fix this,
Thanks in advance,
Mehdi
(CID:102236654)
Hi Mehdi,
Whenever there is a lack of information but the device discovers, it is likely due to a DDF issue. For this specific case, you need the DDF for this device. In the future, you may want to go to multivendorsupport@apcc.com as they create DDFs. For this issue, I happen to have the appropriate DDF.
Steve
(CID:102236660)
Hi Mehdi,
Steve
(CID:102236660)
It works, thank you so much. I suspected a ddf problem but I expected to find the file on the APC website, since the ACRC301s is an APC product but I did not find it. Thank you again, Mehdi
(CID:102236675)
Posted: 2020-07-02 03:24 PM . Last Modified: 2024-04-09 03:10 AM
Welcome, not sure why it has not yet been included in the DDF download option but I will ask that it be addressed.
(CID:102236683)
I have the same issue with ACRC301S, can you send me lastest DDF file?
Kind Regards,
(CID:110005130)
Hi Joao,
please see my previous response as it has a link to the DDF. If that one isn't working, use:
you can find DDF files there and request those that are not available.
Steve.
(CID:110005135)
Posted: 2020-07-02 03:25 PM . Last Modified: 2023-10-31 11:34 PM
