Sensors in DCE and DCO
  • EcoStruxure IT forum
  • Sensors in DCE and DCO
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 08:42 PM . Last Modified: ‎2024-04-04 04:06 AM
1234
Hi team,
   I have an environmental sensor providing temperature and humidity values in DCE as shown in figure. However once linked with DCE, I have two objects, the environmental monitor and a temperature sensor, but not a humidity sensor. Humidity is not present in DCO. Is it possible to have humidity as well?
  Thanks!
(CID:132668263)
  • Data Center Operation
Posted: ‎2020-07-04 08:42 PM . Last Modified: ‎2024-04-04 04:05 AM
1234
Hi
DCO does support humidity sensors, but based on your screen shot it seem like you have associated the device itself and not the actual sensor.
When you find the device in the "Unassociated devices" tab, then you can drag each individual sensor (indicated in blue) on to a rack, but you should only associate the actual device with a device inside the rack, although that will not make any difference regarding temperature and humidity.
If your device does not show up with a humidity sensor, then my guess would be that DCE reports that humidity sensor in a way which DCO does not recognize - a situation which sometimes can be remedied by updating the DDF for that device.
Best,
Gert
(CID:132669267)
Replies 6
I'm very interested in this... as we are about to integrate a LOT of these via RFCode Centerscape.
(CID:132668319)
1235
Hi
Best,
Gert
(CID:132669267)
I have asked for the modified DDF, but no news for the moment.
Fingers crossed!
(CID:133367462)
Wes, you might find this helpful:
RF Code CenterScape Connector
(CID:132669270)
Thanks for your answer,
    humidity sensor is not present in DCO, so I assume the DDF is not working well.
    I will try to update it and let you know.
   Regards
(CID:132669282)
Posted: ‎2020-07-04 08:42 PM . Last Modified: ‎2023-10-22 03:53 AM
