Posted: 2020-07-02 10:51 AM . Last Modified: 2024-04-10 12:44 AM
I have upgraded the firmware of a 3 phase SURT20000 to 6.2.0 and since then the following sensors are now showing unplugged in DCE.
I have another identical UPS that is on DCE at version 6.0.6 FW. This one returns data for the above values but does not have sensors for :
The UPS at V6.2.0 FW does have these 4 sensors.
My questions are:
(CID:94601477)
Hi Garry, welcome to the community! We will look into it, thanks for posting.
(CID:94601526)
Hello Garry,
DCE showing a sensor has being unplugged indicates that the UPS is no longer providing data from that specific SNMP OID. It is possible that the newest firmware add or omit SNMP OIDs. Which may be the reason these devices have different sensors. I would recommend contacting our UPS technical support team to determine if the sensors in questions have been removed. Here is North America, the technical support phone number is 800-800-4272 press 5 for technical support then 4 for 3 Phase UPS.
(CID:94601863)
Posted: 2020-07-02 10:51 AM . Last Modified: 2023-10-31 11:34 PM
