Posted: 2020-07-02 10:50 AM . Last Modified: 2024-04-10 12:44 AM
Is there a way to change the cursor (hover over figures) on the EE Historical PUE Graph to 2 decimal places, as we have a research facility wanting to tune their PUE between the 1.15 and 1.22.
The EE PUE Dial shows the PUE in 2 decimal places but the historical graph only shows to 1 decimal place.
(CID:94601476)
Hi Danny, we will investigate it, thanks for sharing.
(CID:94601527)
Hi Danny,
Unfortunately there is currently no way to configure the number of decimals shown.
You are however absolutely right that 2 decimals as in the PUE dial should be shown in the tooltip as well.
I have logged this to be adjusted in a future version so that 2 decimals are shown in both graphs.
If you need a work around you might use our webservice API where the PUE is exposed in the http://
Or you might want to use the StruxureWare Portal where PUE is also exposed in the "Data Center KPI" portlet and here the tooltip is shown with 2 decimals. More information regarding the Portal is found here
Finally we can offer to create a report where the PUE is shown historical, that can be done based on quotation.
(CID:94601690)
Hi Danny,
I'm happy to be able to inform you that the historical PUE graph will report with 2 digits with the next release of DCO.
(CID:94602478)
Posted: 2020-07-02 10:50 AM . Last Modified: 2023-10-31 11:18 PM
