Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Schneider Electric PowerLogic PM800 Series DDF file, integers -> float
  • EcoStruxure IT forum
  • Schneider Electric PowerLogic PM800 Series DDF file, integers -> float
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 02:53 PM . Last Modified: ‎2024-04-08 01:09 AM
1179
Hi team, I do have the following question regarding the powerlogic_8xx.xml file,
ddfid="powerlogic_8xx"
ddfname="PowerLogic 800 series"
ddfversion="1"
Customer is using this DDF to monitor his PM 800 powermeters, all is working fine except we do notice the following, within the DCE client we have for example Apparent Power showing a
value of 62.000 kVA, this value is provided by using the register value 1151, apparent power, total, type: integer, 16 bits,
would it be possible to change this into register 11752 Apparent Power, total, type: float, 32 bits.
And not just this register but all integers that have a counterpart as float. See attached registermap.
(CID:116364067)
  • DDF
1179
Hi Cees De Vogel,
From my understanding, this seems to be an update request for Schneider Electric PowerLogic PM800 DDF. To process your request further, kindly raise an update ticket for this DDF through DCIM Support->Device Support.
Divya Shankar
(CID:116364136)
Replies 8
1180
Hi Cees De Vogel,
Divya Shankar
(CID:116364136)
Hi Divya, hmm, strange, that is what I have tried but that page tells me this, if you encounter issues with a existing device support file, and this is the case then raise you're question in the community
(CID:116364146)
Posted: ‎2020-07-03 02:54 PM . Last Modified: ‎2024-04-08 01:09 AM
Made my request within Device support
(CID:116365150)
Hi Cees
We are working on improving the process of requesting changes to existing DDF files, and it will be possible on our website within short time I expect.
/Jesper
(CID:116921736)
Hi Jesper,
THX a lot, I have already created a request within device support
Cees
(CID:116921743)
Hi Cees de Vogel,
I'm interested in this topic: do the indications of registers 1151 and 11752 differ? If different, how? Can you show in the example above the indicated power meter?
With best regards.
(CID:116364159)
The problem is caused by the fact that by default, the float data storage option is disabled. Check this KB article to enable this option:
http://www.schneider-electric.com/en/faqs/index?page=content&id=FA212299&actp=search&viewlocale=en_U...
(CID:118003877)
Posted: ‎2020-07-03 02:54 PM . Last Modified: ‎2023-10-22 03:51 AM
