Scanning barcode to add serial number
  • EcoStruxure IT forum
  • Scanning barcode to add serial number
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 07:07 PM . Last Modified: ‎2024-04-03 02:45 AM
803
Can you use a barcode scanner connected to PC to add serial number and other information to DCO custom properties?
(CID:143756038)
  • Data Center Operation
Hi Matthew, you should be able to do this depending on the PC software you're using to drive your scanner.  E.g. in the DCO client, put the cursor into the serial number field then scan the barcode straight in.
(CID:143756051)
Posted: ‎2020-07-05 07:07 PM . Last Modified: ‎2023-10-22 03:51 AM
