DCO connect to Active Directory via ssl
  • EcoStruxure IT forum
  • DCO connect to Active Directory via ssl
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 07:07 PM . Last Modified: ‎2024-04-03 02:45 AM
952
Hello
I try create authentication server (Active Directory ) on DCO 8.2.7 without search the group according to the following link
https://sxwhelpcenter.ecostruxureit.com/display/public/UADCO8x/Setup+an+AD+%28Active+Directory%29+Se...
All details that I set is working when I connected via port 389 (without ssl) .
When I change the port to 636(SSL) I got popup and accept to certificate because this not trust .
After I have pressed ok the page is stuck and doesn’t promotion . the page stuck a huge time. In server.log of the jboss I see the java error about NulPointException.
On netstat I doesn’t see that the DCO try open connect to AD on port 636.
Into section “Certificate” on DCO web I see the certificate from the Domain Controller of the AD .
Please note : all process I run like user locally of the DCO (according to manual) .
1.What in this process incorrect ?
2.How I can debug this problem ?
Many thanks in advance .
(CID:143756065)
  • Data Center Operation
Replies 5
Posted: ‎2020-07-05 07:08 PM . Last Modified: ‎2024-04-03 02:45 AM
952
Hello
Try adding certificate authority certificate to the DCO server.
  1. Root CA added to /etc/pki/ca-trust/source/anchors/
  2. update-ca-trust extract
  3. reboot
(CID:143756461)
Many thanks for answer .
Can I add the certificate authority from AD via webmin ?
Rally I didn’t understand how I add CA ?
Is this crt file that I need  to copy to this folders only ?
(CID:143757476)
Hello
Is there link for add certificated DCIM for Authentication  Server issue
(CID:143758583)
Hello
Is there clear knowledge regarding to add certificate of the AD to DCO ?
Which the certificate I need and how I can get it ?
Thanks in advance
(CID:143760752)
Posted: ‎2020-07-05 07:08 PM . Last Modified: ‎2023-10-22 01:43 AM
