Posted: 2020-07-02 01:19 PM . Last Modified: 2024-04-09 04:35 AM
Hi Community,
Can I save and export the new equipment browser setups - so that when you either upgrade or re install the client - the new formats can be saved and re-imported?
Kind Regards
(CID:97485874)
Hi Hiren,
As I understand the request it is like a equipment browser column configuration/layout export/import.
That is current not possible within the client. The information is however saved somewhere in the user configuration files which might be possible to manually copy/move to the new client install. I will investigate further...
/Søren
(CID:97485941)
Hi Hiren, The configuration is stored in the OS specifik PreferenceStore which is not something that I would recommend modifying/copying. If you want to log this as a feature request it can be done here: http://dcimsupport.apc.com/display/public/Feature+requests /Søren
(CID:97485952)
Posted: 2020-07-02 01:20 PM . Last Modified: 2024-04-09 04:35 AM
Hi Soren, Thanks for the update, I have logged this as a feature request. kind Regards Hiren
(CID:97485961)
Posted: 2020-07-02 01:20 PM . Last Modified: 2023-10-31 11:34 PM
