Posted: 2020-07-04 03:35 AM . Last Modified: 2024-04-05 03:16 AM
Hi Team,
I do not believe SSO is supported by DCO (Jef answered similar question here ) but just making sure there is no other way to make a direct connection (direct link or similar) to allow customer access his Tenant Portal page directly?
Is SSO planned to be added in a forseable future?
(CID:128061230)
Hi Lukasz,
You are right, SSO is not supported in DCO.
Currently the supported user authentication is either via DCO server itself (local users) and/or via the integrated authentication server type: Active directory, Data Center Expert, LDAP.
I think the possibility for SSO authentication will be looked into/investigated in near future - however I have registered a feature request and will send you a direct confirmation as well, thanks.
Kind regards
(CID:128061295)
Hi Lukasz,
Kind regards
(CID:128061295)
Thank you Jef
(CID:128061331)
You are most welcome, Lukasz
Kind regards
(CID:128061333)
Posted: 2020-07-04 03:35 AM . Last Modified: 2023-10-22 03:51 AM
