Posted: 2020-07-04 02:43 AM . Last Modified: 2024-04-05 03:44 AM
How to reset the password for struxuware DCE 7.4.1?
lost the credentials!
lost
(CID:126185240)
You need to have physical access to the server:
Please follow these steps in order to reset the password on ISX Central v5.1 higher:
1. Hook up monitor/keyboard to ISXC or setup hyperterminal serial session.
2. Reboot ISXC (by cycling power)
3. Login within 5 minutes of ISXC reboot with the following username/password:
username: apcreset
password: apc
4. Follow instructions when prompted to reset apc admin user to factory defaults (i.e. apc/apc)
5.Login to the Central client with the apc/apc as admin user/password, goto Settings-Users and Device Group Access to change the Central's user and password specifically.
(CID:126185247)
username: apcreset
password: apc
(CID:126185247)
Thank you Balaraman.
It Works perfect
(CID:126881003)
You are welcome Ernesto!!
(CID:126881005)
Posted: 2020-07-04 02:43 AM . Last Modified: 2023-10-22 03:47 AM
