DDF file for monitoring UPS Delta 3kva with DCIM
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • DDF file for monitoring UPS Delta 3kva with DCIM
126
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-04 02:42 AM . Last Modified: β€Ž2024-04-05 03:44 AM
978
Hi, I need ddf file UPS Delta for monitoring whith DCIM expert.
I need this? Someone have any suggest?
(CID:126184912)
  • DDF
978
Dear claudio.cornejo,
Searching for EcoStruxure IT, under Device Support with the UPS filter, shows the following result:
You only need to specify the part number or model of your UPS. Then, a suitable DDF-file can be obtained by clicking on "I WANT IT TOO". And within one business day you will be sent a link to download the DDF-file.
If the above mentioned search result does not have your UPS, then you need to create a new Device Request, as described in topic .
With respect.
(CID:126184940)
Replies 4
979
With respect.
(CID:126184940)
Thank you very much!
(CID:126185125)
Ok, glad to help πŸ˜€.
(CID:126185123)
Posted: β€Ž2020-07-04 02:43 AM . Last Modified: β€Ž2023-10-22 01:48 AM
