Posted: 2025-04-09 09:20 PM
Hi Community,
Seeking some advise and would like to know if anyone has managed to successfully implemented this.
EIT Gateway v.1.24 installed on Windows Server on LAN.
Trying to figure out how to complete self-sign the CSR generated from this guide here:
I have managed to get to step:
Create a certificate signing request and a new SSL certificate signed by a trusted CA
Type the command:
"C:\Program Files\EcoStruxureITGateway\<current Gateway install version>\jre\bin\keytool.exe" -certreq -alias dcos -keystore dcos.keystore -file newSxOnGW.csr
I have the "newSxOnGW.csr" file in the \keystore folder generated fine.
however the below values are not prompted when executing the above command
Enter the required values when prompted. The first value must match the hostname or FQDN (Fully Qualified Domain Name) of the server where EcoStruxure IT Gateway is installed.
Furthermore the steps below which is after the above steps:
Import the Root CA and Web Server SSL certificates to the EcoStruxure IT Gateway keystore
Copy rootca.crt and newSxOnGW.crt to the machine where EcoStruxure IT Gateway is installed.
I am using OpenSSL on Windows, could someone provide some information on how to generate .crt and rootca.crt from the newSxOnGW.csr so I can continue with the steps 3 and onwards ?
Many thanks
Posted: 2025-04-10 11:17 AM
Hi @wasabi,
We had a look at the instructions in this article. The section Create a certificate signing request and a new SSL certificate signed by a trusted CA is missing an instruction to take the certificate signing request you created to your certificate authority.
After you create the certificate signing request, you must give it to your certificate signing authority (CA). You will then receive a new signed certificate and the root certificate from your CA.
Once you get those two certs from your CA, you can proceed to Import the Root CA and Web Server SSL certificates to the EcoStruxure IT Gateway keystore.
Thank you for pointing this out. It helped us improve the instructions.
Apologies for a rather frustrating experience. Please let us know whether you were successful after following these instructions.
Best,
Jackie
