Posted: 2020-07-05 08:01 PM . Last Modified: 2024-04-03 01:22 AM
I have added some Raritan PX3 series PDU's and the outlet control feature of DCE does not seem to work for them.
The DDF seems to include for outlet control but the control function is not appearing as an option in DCE.
The Raritan PDU's have the latest Firmware on them and DCE is on V7.6.0
How do I get outlet control to work?
Regards
(CID:144869426)
Posted: 2020-07-05 08:01 PM . Last Modified: 2024-04-03 01:21 AM
Hi Garry,
I know that people have had this working with some non-APC PDUs but I'm not 100% sure it's officially supported. The theory behind it however seems pretty standard so I can only assume the DDF you have either does not support this functionality or it doesn't see this model as compatible with the feature. I left this one alone in hopes that someone on the DDF team might have a look at it.
Can you provide the model info, mib (they probably already have) and a walk of one of the devices? I'm assuming you've tested switching the outlets via SNMP outside of DCE?
Steve
(CID:145850503)
Posted: 2020-07-05 08:02 PM . Last Modified: 2023-10-22 03:43 AM
