Posted: ‎2020-07-03 03:46 AM . Last Modified: ‎2024-04-08 11:52 PM
Are front mounted rack PDU's only for horizontal mounted PDU's? I need to mount vertical bar rack PDU's on the front, both left and right, but I don't see the option to do that. I can only mount them on the rear. Does Data Center Operation support vertical mount, front, left and right PDU's? I have a few racks with Cisco switches with PDU's mounted that way.
(CID:106207573)
Posted: ‎2020-07-03 03:47 AM . Last Modified: ‎2024-04-08 11:52 PM
Hi Lee,
You are right, currently only the Rear (left and/or right) mounting is supported for "Zero U"/vertical rack pdus. Front mounting is unsupported for those rpdu's - maybe device custom properties could be used to make sort of notation that the device is in fact front mounted:
Kind regards
(CID:106207664)
Posted: ‎2020-07-03 03:47 AM . Last Modified: ‎2023-10-31 11:32 PM
