Posted: 2020-07-03 03:47 AM . Last Modified: 2024-04-08 11:52 PM
If I run the Calculated Plane option for my room, I get a temperature map along with the following issue:
(X) There were severe issues computing the temperature map.
When I click more I get the following message:
"There were one or more issues that may affect the accuracy of the temperature map. Insufficient cooling, so the temperatures may be inaccurate."
Has anyone else encountered this? We have more than ample cooling in this room, so maybe we need to tweak the power or heat load settings of our equipment? Relatively new to DCO so we're still playing around with some aspects over here.
(CID:106207580)
Hi Austin,
Without seeing/studding the setup it is hard to say why you are getting this notification. I would check the "Recommendation" tap to see if there is any useful cooling related description. That could be something like if you have downflow crac, consider adding some perforated tiles, etc.
Following page contains some description about cooling configuration:
https://dcimsupport.apc.com/display/UAOp74/Cooling+Configuration+Accuracy+and+Design+Guidelines
You might also want to watch the following video tutorial illustrating how to model different types of cooling:
https://dcimsupport.apc.com/display/73video/How+to+model+different+types+of+cooling
Kind regards
(CID:106207868)
Hi Austin,
Kind regards
(CID:106207868)
Posted: 2020-07-03 03:47 AM . Last Modified: 2023-10-31 11:38 PM
