Posted: 2020-07-03 05:15 AM . Last Modified: 2024-04-08 11:24 PM
What user rights need to be set in order for a "standard non admin user" to be able to view the rack temperatures ?
thanks
(CID:107448521)
Hi Paul Baker, thanks for posting! What version of DCO are you using? Best, Stine
(CID:108234605)
Hi Paul,
The only thing user needs is access to the room (even the "View" access would do). Here is an example for a user with no admin rights at all, having only the "View" access to the data center:
Works the same, both for 7.5 and 8.0.
Kind regards
(CID:108234667)
Posted: 2020-07-03 05:15 AM . Last Modified: 2023-10-31 11:32 PM
